jdtractor
- March 3, 2014
- 2007 ford sport trac 4.6
ok so i installed 31 10.50's on my truck, havent used the 4x4 since, well the other day got in a rough spot at the pond and engaged 4 auto and it would pop then stop pulling start pulling agian then pop and stop pulling, so i put it in neutral engaged 4 low, same thing, so pretty much every time it makes its loud sound under the truck it stops pulling for a sec then you hit the gas a little it graps agian, with that being said what else should i look at before i straight rule it a slipping chain in the t case? i would hate to rebuild it then i still have the same problem lol. cv axles look good no ripped boots or anything, now ive worked on race car for years but i dont know jack crap about 4x4 systems so im slowing learning the diagnostics, could it be a bad auto hub? or how does the front axles get locked in? see use to when i hit 4 low it made a load clunk when it engaged now it doesnt make that noise 98% of the time. only time i ever use 4x4 is when im at the pond or state forest and i get stuck it dead sand or mud but its never nothing bad just enough to where you need a little help from the front tires to pull out.
