Transfer Case Motor Half Fixed ! | Ford Explorer Forums
Mike B
Well I got the Transfer Case to shift into 4 Hi !
92 Explorer !
Changed the Motor , Control Module , Dash Switch !
Well I found the Circuit Breaker on the Hot Wire coming from the Fuse under the hood its Located under the dash on the Pass. Side !
Also the Haynes Book and The Ford Manual shows a Black with a White Stripe coming from the Under Hood Fuse well its Wrong Its Dark Green With a Light Green Wire I found it Corroded in half spliced it back together and Tried the Dash switch the unit Works but I dont Have 4 Lo !
The wire was Corroded from the Acid from the Battery !
So do a Little lookin and see if anything is Abnormal look before you need too use it and you try it and it dont work !
Also there is a Dash light in the Dash Switch to light up the buttons on the switch !
It a Mini light bulb !
In All I got about 12 hrs in this thing !
Hope this helps others !
Mike
