esclamada
- October 25, 2010
- KCMO
- '02 Mountaineer AWD V8
Tried to replace my transfer case output seal today but got in a situation where I can't even take out the driveshaft. The 4 bolts that hold them (12mm) is way too tight that even my tornado impact wrench at 600ft/lbs of torque can't budge them. I soaked them in pb blaster and it just wouldn't come out loose. Although it was torqued at 18ft/lbs I think the loctite made it impossible to loosen them. Any ideas on how to deal with this? Another issue is the big nut in the output shaft flange that is torqued to 262 ft/lbs, with the loctite this seems impossible for a weekend DIY mechanic.
Thought of using heat but it is very close to the gas tank,might be a recipe for disaster if I'm not that careful.
