transmision fluid from breather | Ford Explorer Forums
chrisquelch
fareham hants
2000 northface
hi guys
i have a 1999 4ltr explorer that i just got it is discharging transmision fluid from the breather and the joints on the filler tube.but only seems to do it at motorway speeds 60to 70 i will be removing fluid as soon as can get around to it as i think it has been over filled.but are there any problems that could do this.
cheers chris
hi
will check in the morning just brought it seller said it had an transmision leak but fluid coming out of the breather .so suspect over filled.
cheers chris
so today i removed some of the transmission fluid via the cooler then topped it up to correct level ran it for 25 miles on the motorway all seems fine with the box slight leak from front diff seal and engine oil filter housing. jobs for later.
cheers chris
