jmatters
- September 10, 2007
- Raymore, Missouri
- 2002 XLT
I was noticing that my automatic transmission in my 2002 Explorer was starting to shift hard and/or with hesitation, so I brought it in to a local shop to have the fluid and filter changed. I know, I should have gone to the dealer, like I did last time, which completely took away the problem, but I didn't.
Now, it downshifts hard (both when accelerating after turning and after coming to a complete stop). And, when it is cold, it doesn't want to shift into reverse from park, nor into drive from reverse.
I took it back to the shop and they couldn't make it act up and couldn't find anything wrong.
I looked at my owners manual and it said to use Mercon V ATF. When I looked at the Invoice, it had this:
ATF+4
(then on the next line and indented): ATF3 (then listed the amount used: 5 quarts?)
I don't quite understand- can someone help translate this. Basically, did they use the wrong fluid?
ATF+4
