emfjsullivan
- July 29, 2002
- herdnon, va
- Navajo (Explorer Spt) '93
I've read about changing the xmission fluid on the Explorer Maintenance website (Dead Link Removed) and had a ?: They talk about disconnecting the return hose from the xmission cooler and putting on a new length of tube which will go into a bucket. The new fluid will then be put in via the filler tube.
The ?s I have for my '98 XLT 4x4 are:
1. what about the other side of the connection of of the return line that you just disconnected? By this I mean, when you disconnect a hose/tube, you now have two openings, and the discussions only seem to address one of the openings. So how do I plug the other side of the return tube?
2. When it's all done, how do I gracefully remove the temporary tube w/o spilling any tranny fluid?
I must be missing something so any enlightenment will be appreciated.
Thanks
Thanks
