majorlag
Elite Explorer<br><img src="/forums/images/stars4.
- July 31, 2002
- Knoxville, TN
- 1994 XLT 4x4
Just to show how dumb I am, I have a question about transmission fluid levels that I need help with.
Recently had transmission serviced (fluid, gasket, filter, scrape pan, etc). Since then, have seen some seepage of ATF around the pan. Not too much, but more than the none from before. I've been checking the fluid pretty regularly to see how much fluid I'm losing. Tonight, I checked it after it'd been running for 5 min or so and just shortly after the engine had been revved at 3500 RPM or so.
The fluid level was waaay up on the dipstick, far past the checkered spot on the end. Disturbed by this discovery, drove slowly home and checked it again. Fluid level looked fine--'bout halfway on the checkered end.
OK, now the questions: Is this fluid level variance normal? A sign of overheating? Something to be worried about or is my ignorance just making me hypersensitive? Has anyone else noticed a similar problem after extending their transmission breather line?
Thanks for you help and sorry for the verbose post.
