FORDBOYpete
- October 1, 2010
- East Central Florida USA
- 95 Aerostar XLTN 4.0 RWD
From time to time some things just do not go right. Such is life for us all. I've a '95 Aero XLTN, rear wheel drive (RWD) w/ 4.0L Cologne V6 & Bordeaux Built A4LD-A/T. It had over 240K miles on it when it started to develop transmission problems. The Aero pulls my 16ft 2 axle flatbed tag trailer. I've weighed 14,000 lbs or more fully loaded. I've run east coast from Florida to N.Y. Area & back with it. It's no surprise it needs a fresh transmission. I did flush it every 20K miles, clean or replace the filter & keep cooler lines cooling by adding a air flow cooled cooler from a Motor Home on the return side. We going to be talking about two styles of A4LD transmissions. AWD is what the All Wheel Drive unit which is 4wheel drive of varying percentages is called & known as. The other style A4LD is known as RWD or Rear Wheel Drive which is a 2 wheel drive using only the rear axle & wheels.
I had a pristine A4LD transmission from a low mileage '95 Aerostar with with a badly rotted cargo area floor & rusted out /missing rockerpanels. I removed the Transfer case from it & sent transmission to a "shop" with the A4LD from my RWD Aerostar, to get my RWD extension housing & output shaft installed in the previously AWD A4LD Unit thus making it into a RWD. It should have worked fine. However something went wrong during re-assembly so the unit I picked up & reinstalled in my Aero was bad from the get-go.
Symptom was It slip shifted out of high gear, direct, then would "seek" OD but not shift into it. Or else it would just upshift normally. So the shop added some magic stuff from a can & added a new throttle position switch. I didn't like those two solutions. I do not believe magic stuff in cans, bottles or tubes are any sort of repair. I also know altho TPS controls performance functions of ECU or PCM, it doesn't control shift sequencing. Other factors control shift sequencing. Infact mostly pressures & speeds affect shifting.
Within 75 or so miles of initial repair and only several miles after Magic stuff & pricey unneccessary TPS, reverse began to fail then disappear by developing a "chatter" first, then not engaging at all. When I drained ATF to pull unit out to send it back to the rebuilder, ATF had a metallic cast or appearance to it.
Not a good sign, plus my newly remanufactured torque converter has been ingesting the same metallic looking ATF for who knows how long?
I delivered faulty unit back to rebuilder, then waiting began. I was supposed to get my unit back last Saturday. . . . Not yet. I'm patient, but not stupid. I also try to be fair, but there's a limit to everything. I found a vehicle with a transmission virtually the same. There are several years & models & although they are all the "A4LD" transmission they are not all the same.
First they need to be same size engine as vehicle they are going into. It's not possible to put a 3.0L A4LD on a 4.0L or vice-a-versa or on other engines like a 2.3L or 3.8L.
Second years that interchange are also limited. A parts manual may say 1985thru 1995, but they are not all the same. 1985 had EEC IV based ECU & speed density, 1988 had EEC IV with SEFI, & 1993 to 95 had EEC IV with OBD I while 1996 & 97 came with EEC IV PCM & OBD II. All are different control modules. A4LD transmissions have different connectors & numbers or style/ type of pins in those connectors and so forth.
Third all models using A4LD Bordeaux A/Ts do not have the same year breaks. For example the A4LD from a 1991- 1994 Explorer or Ranger will work in other models such as an Aerostar from 1993 thru 1995. But it will not work in a 1991or 1992 Aerostar. Also in here is model year & build date of vehicles. A 1993 can be built anytime after July 1992 by FoMoCo. There are TSB's, upgrades, modifications and so on, that happen. Even recalls that took place or parts which have been changed may make a difference.
Then we have "AWD" and "RWD" units which obviously do not interchange without some work switching parts and so forth. So it's not an easy thing for a DIY-er or novice to get through, but good news is every once in a while, it does happen. I've been discussing this subject with Brooklyn Bay, because I just happened to "stumble" onto a '93 exploder with a Factory rebuilt A4LD and it's a RWD Vehicle. According to an interchange list this transmission will fit right into my Aerostar because it os a 4.0L version, between 1991 -1994 range of years. Everything looks to be the same, but for 1 small detail.
Ford Exploders in 1993 had their speed sensing via cable from output shaft of the transmission. But Aerostars with RABS have an ESS in rear end and do not use a cable & gear deal. Whatdid I just say???
Aerostars have Rear Antiskid Braking Systems so they placed an Electric Speed Sensor in rear differential thus Aerostars do NOT use a speedometer cable. However, linkage, electronic harness Plugs, and all will interchange it appears to me. All I must do is plug the hole & keep the ATF inside their so it can get burned off as a matter of due course. . . .
I believe I am lucky with this find as the price is great. A4LD is shiny clean the fluid is Kool Aid Red & crystal clear. It also is sweet and not burnt or "hurt"
at all. I will get it this weekend or early next week if I still can. I will also get the speedometer cable end & clamp to fill the hole becausae of where my ESS is located. With this advantage I can have my sorely missed, well liked, 95 Aerostar XLTN 2+2 truck "Back on the Road Again" jus' like Willie & Waylon.
CIAO Y'all
I'll let you know how it turns out
FBp
CIAO Y'all
FBp
