Transmission problems ??? | Ford Explorer Forums
InTrouble
Montreal, but live in Dominican Republic
'99 Limited Edition
I have a weird problem occuring right now. It started 3 days ago. I have a explorer '99 limited edition 4L, 6V with 170 000 miles. I had the transmission rebuilt last year and everything was working fine. Then, 3 days ago, I had the differential (rear) replaced and,since then, i noticed that when i start driving, the shifting is fine but if I'm on the highway at about 60 mph and I reduce speed , The transmission won't shift back up to 5th gear or OD ( sorry, I don't know anything about mechanics ...) and the OD light starts flashing. If I stop on the side of the road, turn the engine off and go again , everything is back to normal until I reduce speed.Then , same thing happens again . It stays in 4th gear no matter what I do ( releasing the pedal , etc ...) . I went to the shop where they installed the differential and no codes shows on the scanner when they connect it. I even went to the Ford dealer here and no codes on their scanner neither.
( Have in mind that I live in Dominican Republic and they are pretty late in technology here so maybe the dealer doesn't even have the right program on the scanner, I don't know ...)
Is there another way to try to find out what the problem is or do I have to
have the transmission rebuilt again ???
Anybody had similar problems ???
Thanks ...
