Tunnel Rat
- October 17, 2015
- Dayton, Ohio
- 2005 Mountaineer
I rebuilt the transmission on my 2005 Mountaineer. The rebuild included the usual rebuild parts along with the sun gear and planetary gear assembly, servo bore holes and the solenoid plug. It is all back together and now it only wants to go forward and it wants to go forward in every gear including park, reverse and neutral. Any ideas?
When I replaced the solenoid plug I checked the wiring diagram a dozen times since the wire colors on the new plug were all different than the wiring harness on the car, I'm sure they are right according to the instructions that came with the new plug.
I'm not sure about the accuracy of my torque wrench so could over tightened bands cause this?
Could there be something stuck in the valve body?
How about a bent connection in the solenoid plug on the solenoid itself.
Any help would be appreciated.
