91explorermatt
- December 4, 2009
- martinez georgia
- 1991 sport
I recently got my explorer 4.0 sport 5speed with an m5od and the transmission crapped out on me. and the ranger's engine is shot but the transmission is perfect and only about 3 years old, but its mated to a 2.9 and is 4x4.
I know that I can put a 4.0 clutch flywheel and started onto the 2.9 trans, but can I just take the entire transmission from the ranger and slap it under the explorer? I think that i can change the out put shaft out from the m5od to the ranger transmission(which I know is not an m5od) but if not than cant the transfer case stay on the back? as long as it doesn't loose fluid I don't see an issue? or is it even possible to take the 2.9 trans and put it behind the 4.0
I figured I'd make a franken car since one has a bad trans and the other has a bad motor then strip the ranger and get money at the scrap yard for it
Sorry if this is in the wrong section I think it might actually qualify as a modify
