Apparently this is a subject no one is famliar with.Transmission filters should be changed every 12,000 miles so if you have not done this in the last year,YOU NEED TO.I cant figure out how to post pictures,but i will do a step by step anyway,considering I found nothing on this and no one had any input.
STEP1-Remove catalytic converter(i have 4.0,4x4,auto tranny dont know if this applies to other motors)I used a sawzall because i dont have emmissions testing.
STEP2-Remove back bolts and let as much fluid drain as possible.Let the pan slightly drop,but dont put to much pressure on it,because it could warp the flange.Leave the front bolts in,but slightly loose.
STEP3-Finish taking the bolts out and let the rest of the fluid drain and drop the pan.
STEP4-there is one bolt holding the filter in.Remove it and pull the old filter out.Be sure to make ceartain the old o rings come out with the filter.There are two o rings.
STEP5-Install new o rings and filter,reinstall the bolt holding the filter in.
STEP6-Clean pan with brakeclean especially the rectangular magnet in the corner.After pan is whiped clean,spray it again with brakeclean to remove any lint or contaminates.
STEP7-Lay the gasket on the pan and start all your bolts loosely.I like to use a drop of loctight on all the bolts to prevent future leaks.Once all your bolts are snug,start torqing them down in a star formation.I dont know what the exact torque specs are,i use a quarter inch ratchet to make sure i dont overtighten.
STEP8-Fill transmission back up using mercon5.I strongly reccomend full synthetic.Usually the pan only holds about 5 quarts,but start with 3 then add more to prevent overfilling.
Hopefully this will help somebody out,it is extremely easy once the converter is out
