grumpyoldgamer
- May 4, 2013
- three rivers michigan
- 2007 sport trac limited
truck thinks its running hot? UPDATE
so i have a 07 st with 63000 mile v-8 with a new radiator (old one had a crack)
and have been pulling ower kiwi 23 b travel trailer ( 4800 pounds fully loaded) on camping trips. and have been watching the temp gauge witch sets at the bottom of the little thermometer icon on the temp gauge. and for the most part it stay right there right around 212 deg f. but some times even at low speeds say 45 mph. the temp gauge shoots up over the normal range and the i can hear the fan kick in then just as fast the temp gauge gos down to normal and the fan quiets down
this weekend i was pulling and it was warm out so i turned on the air and with in 10 sec the temp gauge pegged out. and we were only doing about 45 mph
so i turned off the air and the temp gauge went back down. again with in 10 sec. at no time did i notice any bubbling or popping sounds or was the over flow bottle full. so is it realling over heating or do it just think that it is.
perhaps its a bad sending unit? any thoughts or ideas on this would be great
we are taking a long trip in august ( 4 hour drive) and its bound to be hot
So the truck went in to the ford dealer and have found the problem. Its the top temp sensor like I thougnt there is a 40 deg diff in the coolent and the gauge reading the jobis going toabout 670+ they haveto take the intake manafold off. Ouch!
