Justin_
- March 30, 2020
- Missoula
- 98 2-DR Sport 4x4 4.10
- Callsign
- KJ7IKI
Hey guys. I have a rough idle issue on a 98 SOHC that I cant seem to chase down. Hoping I might be able to get some help.
My Explorer is having issues with idling. It will idle rough with revving and has bad exhaust burn (you can smell it). The rough idle /mostly/ goes away when it warms up, but still has bad burn. It also has developed an issue starting up when it's below freezing (new this year). It has a bit of an issue accelerating from a stop, and the throttle response is a touch slow. It also tripps codes P0172 and P0175 (bank 1 rich, bank 2 rich) when driving in town, but not when on the highway. It will sometimes trip P0171 and P0174 (bank 1 lean, bank 2 lean) when on the highway.
Here's the thing though. If I disconnect the battery, wait a bit, then plug it back in, resetting the codes, it will work fine. You can't smell any unburnt fuel, the idle is PERFECT, the acceleration is great, throttle response is improved, and it just feels great. However, once the code is set again it reverts back to the pour performance. This happens in 10-20 miles in the city, but can take much more on the highway.
For one reason or another, in the last 2 years the MAF, IAT, front O2's, intake seals, PCV valve, injectors, plugs, wires, coils, filter (AIR), filter (FUEL), fuel pump, FPR, and fuel return line have all been replaced with new parts.
I checked the TPS out and it was fine
I removed the driver side catalytic and bypassed it with a hose (no downstream O2 on that side).
All vacuum lines have been gone over or replaced.
When I got the truck just over 2 years ago it was fine, it has been slowly getting worse ever since.
Any idea what else I should look into? Kinda at a dead end. Been chasing this for over a year and don't seem to be any closer.
This truck did roll about 18 months ago, but this was an issue prior to that too.
