expo5.0
- October 18, 2001
- Red Wing, MN
- 1996 xlt
I am trying to get as much bang for my buck etc. by modifying my explorer. it has 155k on the odometer right now.
here is the current plan-
new custom ground cam (got a great local place to do it), springs retainers etc. etc.
the new torque monster headers- or modded stang long tubes (see below)
high volume cloyes oil pump, timing chain, water pump etc. while im in there
255 lph in tank fuel pump, kirban adjustable fpr, stock injectors (the shop can modify them to flow as well as like an aftermarket 26# or so they say)
msd dis4 ignition upgrade, new wires, and new copper plugs
NOS 5115 nitrous kit (100 shot)
bottle warmer, purge (just fo show), nitrous and fuel pressure gauges. later down the road a remote bottle opener
and finally a complete custom burned flip chip done on the dyno at his shop
I still have a couple of completely unresolved issues. i hope many of you can help shed some light on them etc. and as i learn th answers either from here or elsewhere i'll let everyone on here know as well.
1. how far off are mustang long tubes from fitting? these guys are willing to redo parts of them for a very reasonable rate. they feel i'd be much better served with those than with the torque monster headers etc. what do you think about this situation? are the torque monster headers what i want to produce as much power down low as i can?
2. i want to keep this as quiet as possible. it will def. have a high performance type sound more as a byproduct of the parts than as a result of my "race" type exhaust system. I don't want to ruin my stereo or my image by getting it real loud. I currently still have all 4 stock cats (with 155k on em) and a dual in dual out 2.5" magnaflow muffler. the system has no tips on it, just 2.5" pipe dumped behind the axle out of site.
would you remove cats? will i see power gains by removing the cats? will it get louder if i do so? i know that dual 2.5" will be more than enough etc. for pipe sizes, but currently that section of my truck is much smaller than that... should i upgrade that section? i don't need to pass any emissions, but i want it quiet. let me know how you would set that part up on a budget...
3. should i leave my truck awd? i def. will not be using it in the winter in the future etc.. i know the awd system has a lot of weigh to it etc. how much would it cost me to swap to 2wd? should i just leave the front driveshaft disconnected after i go to the dyno, and be 2wd for a while and have the ability to go back? whats your take on this situation? also, how hard is it to disconnect it on my truck?
also, what size pipes will the headers be expecting? stock right? what about most mustang headers?
we are hoping to see a 50-60 hp gain at the wheels without the nitrous from my current essentially stock + e cam set-up. with the nitrous i hope to lay down some real nice power numbers.
too bad i have the heaviest truck of all time with my stereo and it will still be slow as heck.
