Turn signal help on a 2004 Explorer. | Ford Explorer Forums
walterlaskowsi
Kelowna
2004 Explorer XLT
I have a 2004 Ford Explorer XLT. The turn signals stopped working today. O nthe dash the arrows light up, but no flashing. The hazrds work fine. Is it the switch then and where is it located on these beasts??
Walter
check for a burnt out bulb first then the flasher.
+1 to check the bulbs first. Always try the cheap and easy things first.
Had the same issue on my 05. I replaced all bulbs, multi-function switch and finally the flashed relay. Turns out it was the flasher relay. No problems since.
