Turn Signal Help | Ford Explorer Forums
Turn Signal Help
Wes Brown
Ames, IA
'99 Ford Explorer 2d Sprt
The other day I upgraded my 1999 Explorer 2dr Sport's stock radio. about two days after. i lost my right side (front and rear) turn signals. i have checked the bulbs in both front and back and that wasn't the problem. i then checked my flasher relay, no help. all my fuses are fine in interior box and under the hood. If anybody has any idea what could have happened or what went wrong, please let me know. :exp: :feedback:
your turn signal switch is bad. Mine would be intermittent and then finally quit on the right side. replaced the switch and it was good.
You don't have to take the steering wheel off. 3 screws for the column cover, and then two screws for the switch itself, the tilt wheel lever unscrews.
