Typical repair cost | Ford Explorer Forums
Typical repair cost
cedriso
tampa, fl
2002 sportrac
Can anyone tell me the ballpark estimate for replacement of the front timing chain tensioners and guides on a 2002 sportrac. I know that the motor has to be pulled for the rear timing chain, but I have heard that the front can be worked on with the engine still intalled. I just want to make sure that the mechanics quote is somewhere close to what it should be. I appreciate any assistance you can provide.
you're probably looking at about $2,500. I'd look for a low milage replacement engine instead. '05 mustang is a good choice to replace the '02 4.0L SOHC motor.
Okay, I appreciate your quick response. I will start looking for a new motor. Thanks alot.
just to be clear, the $2,500 is for pulling the engine and doing both chains. i don't know about just doing the front, but i understand it can be done with the engine in the vehicle.
Understood. I just got a quote in Tampa for 780.00 to replace the front cassettes and tensioners, I think I will jump on that. Thanks again.
750'ish sounds about right for just the front.
Welcome to the site.
