Unlocking all doors | Ford Explorer Forums
Unlocking all doors
april22
2001 4 door 4WD
I have a 2001 Ford Explorer 4 door and I am having some problems with the locking system. The car locks from the panels on the doors as well as the remote and even the automatic lock when driving. None of the doors, including the back latch will unlock with the panels or remote. Any ideas as to why? I've been having this problem for awhile and it's pretty irritating to have to go around unlocking the doors when other people are trying to get in my car. Plus it seems all the doors had this problem at the same time so I don't think it's individual doors or anything.. PLEASE HELP! I would really appreciate it!!
Just had this problem on my 99 about 3 months ago. Had half the interior out trying to trace it down.
First, try to unlock the doors using the rocker switch in the back. If the doors unlock or you hear the relay click, the relay is okay. If they don't unlock, check the relays for the PAT system located in front/above the right rear wheel well to be sure they are working. Since your remote doesn't unlock the doors either, good chance the relay may be bad.
If the relay works, then you probably have a broken wire connection. There's different colored wires for each function of the unlock relay so you'll have to determine which color does what. If you find the relay is good and can't determine the wire colors to look for, post again and I'll look them up. Think I wrote all this stuff down when tracing my problem if I can find it. Colors are probably the same for my 99 as they are for your 01.
Once you determine the wire color to look for, there is a connection for all the unlock wires located in the channel under the bottom door panel plastic trim of the right rear passenger door. Pry the bottom panel off and look through the wire bundle toward the rear. Look closely for the connection as its hard to see among all the other wiring. There should be 3-4 wires of the color you're looking for connected somewhere. There's an insulation wrap over the connection that you will have to remove to check the splice. Mine had corroded and the splice broke.
fraxinusalba - THANK YOU SOOOO MUCH!!! it was the relay! got it fixed spending only $14 when a service guy at ford heard two seconds of my problem and already wanted me and my dad to buy something in the door that was $97! thanks for responding so quickly too!! yayyy after a year of going around and unlocking doors i no longer have to do it! really appreciate it! :D:D
