UNUSUAL ENGINE PULL | Ford Explorer Forums
UNUSUAL ENGINE PULL
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
Building my '79 Ranchero, using ex-police car 5.0L HO and AOD, I swung the engine and transmission in and out while assembled together. Involved having front of vehicle quite high off ground, and lowering them in/out at a steep angle, ~ 45 degrees. Having to get appropriate mount brackets and supports, ass well as rear crossmember fitted, I probably had the combination in and out of there 4, maybe 5 times.
Has anyone removed/replaced a V-6/5R55S combination in 3rd. Gen Ex. while hooked together? I imagine I would remove Transfer Case first: it would make the whole thing too long to handle easily.
Any ideas would be appreciated! I have a 2004 approaching 160K, and fear timing-chain-'itis will be coming.
imp
if you must. i did that on my 71 442, i removed the radiator and grill and most of the front end of the car to get them out together. i think it was worth it though. less time under the car and easier to reassemble the motor and trans. Had to rebuild the trans too ..
@07gtman
Unless you still have the 442, you seem to have become a "Ford Guy". As those protective bumbers came in vogue, and the front of the cars increased in length by a foot, I remember laying on a strip of plywood on my belly, to get at those damned rear-mounted distributors! My boss years later, an M.E., told me if you want consistent unchanging ignition timing, you want the distributor up front. Camshaft "wind-up" causes variation in timing with back mount. Camshaft is like a twisted spring. Not much, but the guy built race cars........imp
only the memory ...been driving Fords for about 25 years, and never own a foreign car..and wish i could get some of those yesteryear cars back now...
