Upgrading to a 130 amp alternator, will it work? | Ford Explorer Forums
TheJMan
Scottsdale, AZ
2009 Mazda 3 Hatchback
I have a feeling my stock 95 amp alternator is going out because it sounds like the bearings are squeaking and the voltmeter dances around all the time. Is it possible to directly swap out the 95 amp for a 130 amp out of a 1994 Limited? Reason being I have an amp and 2 subs and I don't think the 95 amp is sufficient enough.
yep its a direct bolt on application...it will work perfect
cool, thanks!
yep, and you can get your core value back on your old one if you don't mention to them that its a 95 amp one. just slide it to them and act as if its a 130...
.they may or may not give you crap if you tell them its only a 95 amp.
