upper a arm replacement | Ford Explorer Forums
676cyl
Toronto, Ontario
1996 XL 4 dr 4.0L
My X is stock. I have replaced the upper ball joints 2 times (159,000 kms). Now the dealer tells me they need doing again. (bump/bang at drivers foot).
Are there after market A arms/ball joints for a 1996 4 dr 4.0L that have grease fittings ?
Thanks for the help.
Moog makes a far better upper and lower ball joint and tie-rod set than Ford.
Moog's upper ball joint/arm assembly is also supposedly an "improved design" that yields more travel.
From www.autopartsgiant.com :
MOOG K8708T [Upper Control Arm w/Ball Joint] Enhanced Design; Front Suspension; LH; 4WD; 1 Required; I$ncludes Bushings 96.93
MOOG K8708T [Upper Control Arm w/Ball Joint] Enhanced Design; Front Suspension; LH; RWD; 1 Required; I$20ncludes Bushings 96.93
MOOG K8710T [Upper Control Arm w/Ball Joint] Enhanced Design; Front Suspension; RH; 4WD; 1 Required; I$39ncludes Bushings 96.93
MOOG K8710T [Upper Control Arm w/Ball Joint] Enhanced Design; Front Suspension; RH; RWD; 1 Required; I$ncludes Bushings 96.93
Thanks. Do they have grease fittings on them ?
Yes they do.
it has been my experience that Moog has 10 times better balljoints/tie rod ends than anyone else on the market. just my $0.02
