the nuts retaining the alignment shims to the upper arm: 70-100 foot pounds lb-ft.
damper/rubber assembly to upper arm: 22-29 lb-ft.
large single bolt on front bracket: 10-14 lb-ft.
3 nuts to 3 large bolts: 145-195 lb-ft.
*if any of the 3 large bolts or the smaller large bolt show any deterioration, like rust or rot, they must be replaced. You can get replacements at any Fastenal store, about $30.00 for all bolts.
the torque figures above are critical as well as the condition of the large bolts, which are normally yield-to-torque-once. (you can torque them once only, then discard them).
