V6 sohc valv timing | Ford Explorer Forums
V6 sohc valv timing
A.Blaikie
Scotland
98 XLT
Can anyone help on this one, the problem started when the cam tensioners
broke up, luckily it was only the front two they were easily replaced and thought I got away with the timing, however it still sounds sick, a compression checks out ok and the manifold seals are ok but a vac test says only 10 should be 22 therefore the conclusion is valve timing has jumped ? and that's my problem I can,t get a hold of the special tools to time her up, but I think I could work it out if I had the degrees after T D C when the exhaust valve cracks open and then copy the same onto the other bank, has anyone got that info, many thanks in advance.
Alan In Scotland
