TennTechMan
- April 12, 2007
- Maryville, TN
- '94 Sport
UPDATE: Valve Stem Seal Problems: Anyone with Dual Springs, Please Read
About two years ago, I rebuilt my '94 Explorer's OHV engine. I rebuilt the bottom to stock, bought new 95TM heads from Alabama Cylinder Head, 422 cam and double valve springs, and reused the stock rockers, push rods, valve spring retainers (Crane had them on back-order), and no machining on the heads for the valve spring seats. Less than 18 months (~15,000 miles) after the build, the engine had started smoking at idle and would blow a large puff of smoke the first time you push the throttle after a long idle. I suspected something was up with the valve stem seals.
6 months after this all started, I finally pulled the engine to check it all out. What I found was something I had not seen before. More than half of the valve stem seals had seperated from the head and were riding at the top of the valve stem. The seals are still intact and appear undamaged. It looks like they just popped off the head.
Anyone else had this issue? Any way to keep it from happening again? If I put the new valve stem seals on, and it happens again in another 15,000 miles, I probably wouldn't mind too much. I would hate it though if they only last 5,000 miles this time. And if I can keep it from happening ever again, that would be ideal.
The other thing I want to do while the motor is out, is to put in the correct length pushrods and a set of Delta's rocker arms. Ever since I rebuilt the engine, it tapped a lot. I tried to email them this morning, but the email was rejected. I'll try to call them Monday. Anyone else had trouble getting a hold of them? Are they still selling the rocker arms and pushrods?
For anyone looking for more history on this truck, search for my posts created under my name. I've got a pretty good write-up of the motor build with some video too.
