Various driveline noises | Ford Explorer Forums
checkedout
Falling Waters WV
1996 Explorer XLT
driveline noises
The ex is getting up in years now, she has 180k on her and despite the gerital, her groans are getting loader. It's made a 'clunk' in the rear for as long as I can remember, usually when it shifts from 3rd to 2nd or if I'm coasting down hill and it goes from 2nd to 3rd. I don't think it's the transmission. Especially now that it's getting loader, it sounds like the rear end. When I had my trans rebuilt the guy said it was common and that all the fords do it. Anyone have this problem and fix it?
Theres more!
Sorry, I forgot to add that I also feel and hear eveything in the suspension as well. I mean I can hear and feel it even when I run over the painted line on the road! Everything is stock. I did have the front shocks changed about 80k ago. Any help would be great, I don't know a thing about suspension.
rear end noise could be u-joint or slip yoke. at 80K, probably time to change the shocks... chances are it'll need ball joints too. Had mine done at 100K and things quieted down a lot.....
Thanks Tom. With 180k on them (balljoints) it's probably time to replace them. I had it jacked up the other day to clean the shift motor so I took the opertunity to push and pull on everything and it all seemed tight. I couldn't find any play in anything.
Mine has 143k miles and has allot of noises going on as well. I had it inspected and they said ball joints and radisu arm bushings.
I also can feel that the LS in the rear end is wearing out.
With your noise from the rear, id, check the u-joints
