morgfarm1
- January 20, 2013
- Roseburg, Oregon
- 1999 Explorer Limited
Hey All,
I'm new here when it comes to being a registered member, so forgive me if this is the wrong section (though I'm 99% sure I'm in the right place)
I just picked up a 99 Explorer Limited, and it's in great shape with all the bells and whistles, (and a cool paint job that changes from blue in direct light to purple in low light) but there are a few minor kinks with it. (Very Minor)
First being my Cruise Control. It does not work. At all. Period. Fixed
I have confirmed it is in need of the Recall that installs a fuse for the Cruise Kill (The one that causes shorts when brake fluid leaks)
After I get the recall handled, What is suggested to resolve this?
Second, The power door 'lock' switch on the driver's side works ONLY when the door is open. Once you close the door, It quits working. (Yet the Unlock option still works) I've exchanged the switch itself, but no luck. I suspect maybe a kinked wire at the hinge (Where the black cylindrical case is in the door jam) but Not sure, Anyone else have this?
Radio Display not working (MACH Premium Sound) This one I think I've found the answer to, but still need to have it serviced. I'll update when I have a chance to get that handled.
Back hatch lock actuator - Sounds like the gears are stripped. As soon as I look through my Haynes manual to figure out 1) how to get the back trim out and 2) how to get the actuator out, I'll get cracking on that also.
Sun visors loose - I used it the first sunny day I had (in the position to protect my left face) and got smacked in the head by the visor on a left turn. Any suggestions how to cure that? (I already tightened the screws that secure it to the ceiling)
Thanks for any help anyone's got.
The specs, If anyone needs them are as follows:
Yr: '99
Model: Explorer
Trim: Limited
Eng: 4.0L SOHC
Power locks, Power windows, Power sun, AutoLamp. Reverse sensor system & DRLs are not on this model.
Yr: '99
Model: Explorer
Trim: Limited
Eng: 4.0L SOHC
