Bluespear
- February 3, 2010
- Ashford, Kent, England (near London)
- 1997 4.0 SOHC
Since the Haynes Manual seems to be as useful as a chocolate spanner, I will annoy you with my (daft?) questions.
The car is a 97/P 4.0 SOHC, uk spec, 95k. So in no particular order ........
1/ the square fog/driving lights set in the front bumper haven't worked since i got the car. There doesn't seem to be a switch for them & I can't find which circuit they're on to check the fuse. ( does anyone have a set of decent wiring diagrams I could have/copy ?)
2/ the cigar lighter socket doesn't have any power to it & i can't find which circuit its on to check the fuse. If the socket is faulty does it just pull out or does the black centre panel have to come off the dash first ?
3/ the self levelling suspension seems to work ok (heard & felt it adjust) but the rear end seems to squat all the time - can the system be reset to make the car more level (higher at the back) ?
4/ occasionally the engine cuts out at junctions/ traffic lights but only if the heater/ aircon is on - if the main control is at "off" its ok. it did have a fault code for low signal at the airflow meter which cleared after cleaning the connections, but this didn't cure the stalling.
5/ Is it possible to get replacement alarm/locking remotes ? mine is the single button type.
6/ The abs keeps cutting in at about walking pace when slowing gently (on hard breaking its ok) so I've disconnected one of the wheel sensors for now. Where can I get replacement sensors - is it main dealer only ?
7/ Would my car have standard axles or Traction Lok axles ? (i'm changing diff oils & the traction-lok axles use a different grade oil + friction modifier)
8/ Which tranny do I have ..... 5r55e or 4r70w ?
I think that's all for now. Sorry to be such a pain in the arras, & thanks in advance for any advise / answers you have.
Gary
Gary
