Viable replacement intake manifold/temp gauge | Ford Explorer Forums
JW
Third Gen Collector
Sparks, NV
A Troop Of Gen 3s
It appears my intake manifold has a crack in it somewhere in the rear coolant passage on the driver's side. The leak isn't persistent but will drop about 1-2 cups of coolant each time it leaks. I'm searching for a replacement and can find lots of Mustang intakes, but nothing Explorer-specific. Rock Auto has nothing, Amazon has nothing for the Explorer but one for the Mountaineer, which *should* be the same thing, and local parts stores are, naturally, useless. The Mustang intakes have a coolant fitting on the rear passenger side that we don't have, so I assume it can simply be capped and clamped, but hate to spend $300 and be wrong. Does anyone have a source for a new replacement intake that will work? Are there any aftermarket/upgrade options that are worth the cost and trouble?
Also, where is a good location to add a sender for an aftermarket temperature gauge?
Still seeking input on this...
Everyone uses the 2002 version. Just have to cap off some port in the back. A few threads here talking about it.
Was interested in checking out the Mustang version, though I believe it doesn't have our two knock sensor bosses. Dive into the Stang version and let us know. Or search out the 2002 version threads.
Thanks! Apparently, adding the year to the search criteria helped tremendously. That led me to the alleged Mountaineer-only intake on Amazon I mentioned before, so that's the direction I'll go. (Upon further checking, Amazon says it'll fit a 2002 Explorer, so their database needs some tweaking...)
Anyone have any thoughts on the temp sender? Do I just "T" off the existing fitting and add the factory and aftermarket there, or is there another (or better) location for a sender?
