Craigerz
- December 4, 2016
- Fort Worth, TX
- 1997 5.0 4x4
Good afternoon,
Took a trip recently to the beach. It was about 300 miles there. Spent the day driving on the beach in HI 4WD. 4406. Nothing hard, no getting stuck no deep water crossings. I didn't even get the tires wet actually. I did air down to about 16 PSI because the sand was dry. Other than that it was an easy day and drove about 35 miles on the sand. Pull onto the highway filled the tires back up and took off. As soon as I got up to speed there was a horrible vibration/noise. My first thought was a tire since that was the only thing I messed with. Played with the pressure and nothing. It feels like its coming from the drivers side floorboard. Now I have it narrowed down to 68 MPH. 68 it doesn't vibrate and 69 it starts and does not stop at a certain speed. 77 is a high as I went.
1. Got home and rotated the tires. Nothing. I didn't have them balanced yet because I figured an out of balance tire would have changed something at least.
2. Checked Diff and t-case fluid both full and front diff is tight.
3. Pulled the front driveshaft and it still does it.
4. The front locker ratchets and engages in 4WD like normal.
5. All front end bushings are new and poly and seem to be tight.
6. New ball joints upper and lower and no play that I can see.
7. All 4 shocks are new with new rear leafs.
8. Both CVs are new although they are the cheaper ones from Rock Auto if I remember correctly. It doesn't have the clicking sound I've always heard from bad CVs.
9. Both front hubs are new but they are the cheaper ones also. Maybe 15-20k miles on all front end parts basically.
10. Have not done the tie rods but there is no play or road walking or pulling nor are my tires wearing unusually.
11. Transmission mount doesn't seem to be torn or broken.
12. U joints were all replaced with the 4406 swap but that doesn't really mean anything now days.
13. You cant really feel it in the steering wheel its more like the floor of the truck is shaking to death.
14. It doesn't seem to have the wha wha wha drone of a rear end bearing.
15. Still have all gears and reverse and shifts smooth. Still shifts into HI Low just fine. No grinding or what not.
I still haven't checked the rear driveshaft.
I guess I can re torque the cross member and check for maybe a broken engine mount?
When it cools off I am going to crawl under it and finish looking for lose or broken drive line things.
Any other suggestions?
