08EddieCA
- March 31, 2016
- Location
- CA
- Los Angeles, CA
- 08 & 03 X (Eddie B & XLS)
I installed a new motor and installed a new flex plate. Flex plate is warped. Had a few shops look at the truck and all came to the same conclusion.
Except for the massive massive vibration that runs through the entire truck, at 2,700 rpms and higher, the starter is a the key to helping us diagnose this problem. When starting the starter makes a changing sounds as if the distance between the starter ring moves closer and away from the starter shaft.
I tried new mounts, new front driveshaft, ran the truck without the accessory belt (in case it was the fan or fan clutch) and installed a new transmission mount. Removed front drive shaft. Engine checked out fine by the dealer. Trans checked out by the tranny shop and they found no issues with the trans (they even serviced the trans). Tires have been rotated and balanced - plus they are six months old. New plugs, again. Plugs look fine. Exhaust is solid but rusted with good hangers/damners. Hopefully the front pump of the trans has not been affected.
My question is: do I slide the motor forward to gain access to the flex plate bolts or do I slide the transmission back? I would much rather slide the motor forward to gain access to flex plate. This is what I'm more comfortable doing.
Any tips on the installation of the new flex plate if I move the motor forward? I have the tightening sequence from the shop manual.
