popscott
- January 2, 2012
- 99 Ford Explorer
Howdy.....New guy here. Was hoping you folks could please help me with my problem.
99' Ford Explorer 4.0L SOHC
Xmas day it konked out. In Indiana, but I live in VA. No tools so had it towed in. Chevy dealer only one open (26th). They put new spark plug and wires, and fuel filter. They did not get it fixed. Repair (Chevy) and tow (U-Haul) from IN to VA $1453 and it still not running.
Symptoms...
Will start right up on cold or morning start.
Will run on and on as long as I let it.
If you then turn it off, it will not restart.
If I'm lucky, after much cranking can get it to finally to start with TLC on the gas pedal, but stalls when put in gear.
It seems to be cranking fast, maybe, maybe not ??????
Engine light NOT coming on and no code read on my scanner.
60 lb. fuel pressure (per mechanic)
120 psi on random cyl (no. 5) (Did not remove all plugs and open throttle up)
Thanks in advance,
Scott
Symptoms...
Thanks in advance,
Scott
