Washer Fluid | Ford Explorer Forums - Serious Explorations
Washer Fluid
spieg16
New Hope, PA
'97 XLT
Hey guys, I just had a quick question about my washer fluid problem. When i push in the switch for my wiper fluid the pump seems to work very intermittantly. I can hold the switch and and the wipers will move but no fluid comes out then sometimes the pump will spray some fluid then stop again then start again, and sometimes it will work perfectly. The rear wiper fluid seemes to work fine though. Hoping to try and get this fixed before windows icing over is a problem.
Thanks, Jason
I had exactly the same problem along with turn signal and intermitment wiper problems. Installed a new multifunction switch and now everything works fine.
Art
How much work is involved with installing the multifunction switch?
just picked up a multifunction switch today, but im having trouble getting the steering column covers out. The top one seems to be really wedged in tightly, and I cant figure out how to get the bottom one over the tilt wheel handle.
