Water Pump Info | Ford Explorer Forums
Water Pump Info
Fordpwnzchevy
VA
92xlt 2wd
I've never put a water pump back on before and i was wondering how tight to torque down the screws that hold it on. Also was wondering how the heck to get the pulley off the old one? Thanks in advance.
I dont remember the specs, but to get the pulley off, you need to have the belt still on, preferably with the fan and clutch removed, but can be done eitherways, then loosen the four pulley bolts. Then pull everything apart, belt first. install is reverse.
