We fixed the rugh idle it was easy | Ford Explorer Forums
JOANN2128
WEST PALM BEACH FL
2010 Explorer 4x4
It was the rubber hose that goes in the brake booster
where it goes in that rubber grummet now it runs great
i'm so happy
Check all the other Hoses and Plugs that plug into the "octopus" on the Manifold where this large Brake Booster hose went... they get worn and loose fitting and can just fall off. Sometimes the ends brake off the the one or two plugs so check for dried out hoses and plugs. You might want to tie wrap them on.
i have a booster where the rubber grommrnt itself is leaking, the hose from the tree to the booster is fine, any idea's how to replace or fix the grommrnt itself?
I found a little kit at pep boys for like $3 or $4, brakes actually work now.
