Scot from S.C.
- January 13, 2005
- Greenwood, South Carolina
- '96 Eddie Bauer
Hi all, I am a new member in search of some help. I have a '96 V6 Explorer with about 173,000 miles on it. It has been a great vehicle up to this point. On occasion, maybe once a week or so, it can be very hard to crank. In addition, when I get it started (with a combination of me giving it gas to encourage it to keep running), it wants to choke down and the rpm's will want to run low with the battery light coming on when it gets low (I guess to show that it is about to cut off.) Now after I keep my foot on the gas, feathering it around 1500 to 2000 rpm's, it will finally catch right and I will be able to take my foot off of the gas and drive away. I have tried fuel injector cleaner, I have checked the battery for corrosion and even had the battery and alternator checked. Does anyone have any clues? All of the plugs and wires seem to be fine as well.
I have a second problem that may be related to the first one. My shift selector over the past couple of months or so has someone gotten off track a bit. In other words, it still goes into the right gear, but the little red marker is a bit off of center where it used to be. In fact, when I put it in reverse the back up lights don't come on anymore. I have to hold it manually nearer the R to get them to come on if I want them on.
I am sorry to be so long winded, but I was hoping to try and get some advice for my problem. The garages around here, much less the dealerships, overcharge to the extreme. Thanks so much in advance!
