OK everyone need some help. I have a 1995 Explorer and am having electrical issues with the A/C. When I switch the A/C on the compressor will not come on and the WOT relay cycles causing the motor to rev up and down slightly. I have checked for 12v at the WOT relay and have it but if I try and jumper the connection the compressor will not come on. If I apply power to the compressor the clutch will engage. While checking power at the high pressure cutoff power is cycling with the WOT and engine. I have tried a replacement computer but that did not help. I am thinking of of the engine sensors is giving a bad signal causing the A/C to not come on. Anyone have any ideas?
Thanks,
John
Thanks,
John
