Thanks everyone for your help.
I think the problem is in the EATC module for the following reasons
I disconnected the AC clutch solenoid and hard wired it to a on off switch that i installed under the dash.
I used the High Pressure Cut Off switch 12 volt source, downstream of the switch, to power the loop.
This way I can manually cycle the AC clutch.
The loop functioned as designed and the compressor engaged and i get cold air at the registers.
However, with engine running and a digital meter connected to the , now disconnected clutch connector, I read voltage readings from 0 volts to 11 volts depending on EATC setting, ie max AC, Automatic with a requested set point, blending door setting etc. and the worst thing was the voltage reading appeared to be random and non repetitive.
I believe my work around would be ok if I manually cycled the clutch periodically .
This is based on a rather dangerous assumption.
1. With a functional EATC The compressor is cycled off when the user setpoint is achieved.
2. The compressor is cycled back on when cabin temperature is above setpoint by some margin
3. Allowing for setpoint deadband, loop hysteresis, and overall loop accuracy, I assume this to be between 3 and 5 degrees so as not to create a continuously cycling clutch. Not sure of the algorithm with respect to temp drop over time
4. If ( and this is the dangerous assumption) setpoint is never achieved, ie. AC system age, then the compressor is always on.
5. If max AC is requested, then the compressor is always engaged, never cycled. and the only protection is the High Pressure Sw.
Assuming the above is reasonably true I should be ok to operate manually while I remove the EATC and service / replace it.
Anybody please let me know if this is not ok
