JayT
- November 1, 2007
- 2003 Ranger, 4cyl 2.3L
I had the truck on the highway this weekend, and the temperature gauge needle spiked from the middle where it normally is to full HOT in around 2 seconds. I immediately got off the gas, and coasted to the shoulder. By that time the temp returned to normal. I checked under the hood and nothing seemed abnormally hot.
Temp gauge stayed at normal, but I was watching it more closely of course. After 10-20 minutes it would do a quick spike to full H, and when I coasted I counted 7 seconds and it would drop straight back to normal.
I did a search on this and found a thread describing the same problem, but they never said what the solution was. I don't know if I have a bad sensor, bad gauge, or what. I've never seen an engine overheat instantly without a cloud of steam from a blown hose, and I've never seen an overheat cool down to normal in 7 seconds.
The only think I can think is there is something going on with air in the system, because I do get some gurgling sound when I turn the heat on in the morning. Reservoir is at the full mark. I have "burped" it a few times to relieve whatever air may be in it, but the problem continues every 10-20 minutes of highway driving.
