mechjames
- September 27, 2007
- Richmond, BC
- 1994 Explorer XLT
A local wholesale dealer (which the prices don't seem to reflect their name) had a 2002 sport trac fully loaded, leather interior, sunroof, pioneer stereo, etc. any option, and it had it.
172,000km. Engine had none of that SOHC timing chain rattle. Started up fine and transmission was good.
Only issue was a humming noise, seemed to be coming from the drivers side front wheel bearings or even possibily from the front axle itself. Got louder up to about 50-60km/h and then you couldn't really hear it after that. More line a humming noice, not a whine or screech, maybe a little grinding but not much. Mostly humming.
I check, and the 4x4 sport tracs have the hub/bearing assembly as one unit. $140 from rockauto, not too bad. Easy problem I could fix, but I didn't let him know I would fix it. I planned to get a quote from an expensive shop and try and get the price down more. Listed was at $8995, internet price was $7995, and i got him down to $7500 due to the bearing issue.
Is the bearing/hub assy a common problem on sport tracs? Or could I be looking at something more serious like a front cv or the front axle itself? I didn't test the 4x4, didn't want to bring the truck back broken.
I'm hoping if it sits on the lot for a while i can get it down to 7000 or 6500 due to the bearing issue, because if someone test drives it, they should immediately hear that something isn't right.
