Wet front drivers side carpet???????? | Ford Explorer Forums
jixie
'99 xlt
99 xlt stock---water leak somewhere? I had the windshield relpaced. Dont smell anti freeze, had the cooling system checked out----they say its OK.
anybody got an idea--help
Jim
You said you had the windshield replaced, take a hose or go to a car wash and run the water over the roof, have someone inside to check for leaks.
Also if you have a sunroof/ moonroof, make sure the drain tubes aren't plugged up with debri, this is a common issue and it'll cause rust in the moonroof area and leaks in the headliner as well as in the floor and dash.
