What Amp For My New Polk Polk Dual db124? | Ford Explorer Forums
ridinonblue
Rogersville, Tennessee
1999 Ford Exporer
What Kind Of Amp Should I Get For My Polk Dual db124 Box?
Here Is The Features
¾ inch MDF: The 3/4-inch MDF is the same low resonance material used in the world's finest speaker enclosures.
ABS Trim: The front baffle is clad in automotive grade ABS trim for rigidity and resistance to impact. A sheet of Elastomeric damping material isolates the ABS trim from the baffle as it acts as a sealing gasket for the woofers. This "trilaminate" sandwich construction prevents unwanted rattles and resonance, ensuring bass that's as tight as it is powerful.
Power Vent: Polk Audio's patented Power Port venting technology reduces air turbulence at the port mouth for higher bass output with vastly lower noise and distortion compared to conventional ports.
ABS Grilles: Wheel-style heavy-duty ABS grilles protect the drivers from shifting cargo. Grilles and baffle may be painted to match the vehicle's interior color.
Single Voice Coil: 4 Ohm drivers wired in parallel for a net 2-Ohm load, optimum for today's Class D subwoofer amplifiers.
Fire-retardant: Flat NOMEX Spiders allow extended linear motion while providing highly reliable mechanical and thermal stability
Bullshit. Birch ply sounds WAY better than MDF.
