What ATF Fluid You Recommend | Ford Explorer Forums
2000co
Englewood, co
'05 Mountaineer V6 AWD
I’m going to change the transmission filter on my wife 05 Mountaineer. The truck got 95k miles and the previous owner did a complete flush at the dealership at 80k but never replaced the filter. The transmission working great just want to replace the filter.
I contact Valvoline and Ford to check if the Mercon V they are selling is synthetic blend and both told me its premium oil not synthetic blend. From what I read so far I need to stay away from the maxlife ATF because it’s not approved Mercon V.
I would like to put the Mobil1 Syn ATF but I’m worried that the old transmission will start slipping with full syntactic fluid, am I wrong?
Is there any diffrance between Motorcraf, Valvoline or Castrol Mercon V fluid? Any other option except Royal Purple that cost $15.
I was thinking to add a conditioner because the high millage, what you recommend? Thanks!
I use Mobil1 in both of mine the 02 has 245kish and the 03 has 120kish. I don't use conditioner but many speak highly of Lucas.
Do you remember the cars miles went you start using mobil1?
Mobil 1 meets Mercon V specs and is only slightly more viscous than the motorcraft fluid so no worries with regards to mileage on the transmission. No reason to run a conditioner with a synthetic.
The reason that the filter didn't get changed with the fluid is because the factory maintenance doesn't call for it.
Thank you! I'll use the Mobil1.
