Mr. Limited
- January 25, 2000
i tried to wire an amp by using the factory amps inputs and power wires from the harnesses. I ran seperate power directy to the battery, but i am trying to take the input signal and remote lead directly off of the factory amp. for input i used a line input converter because my amp uses RCA's. On my 96 explorer 4 door it has the amp and sub in the cargo area, but then theres a seperate what looks to be another amp or some sort of "brain" just in front of the facory amp/sub(passenger cargo area side panel must be removed in order to see it) - this has a lot of harnesses pluging into it with many wires, it also has the factory amps input wires coming out of it. This means that from the factory head unit the wires go to this "brain" and then to the factory amp--actually the power wires for the factory amp comes from this "brain" also(i think). My question is which wire is for the remote turn on because the factory amp seems to have none going to it since i tested all for one. and sould i take the input signal after or before this "brain"-this means from the head unit or from the factory amp harness.
sorry for the length but i want u to understand every detail since i'm sort of lost at this stage.
**any help at all i'd be greatly thankful for.
-Thanx a lot-
-Thanx a lot-
