Laura C
- February 17, 2017
- Kentucky
- 1997 Explorer. 4.0 4wd
We recently bought a 1997 4.0 4wd explorer. The only major problem that we knew of was a bad transfer case. It whines when you let off the accelerator and it also makes a whining sound in reverse and won't move about 30% of the time in reverse. My husband was moving it into our barn to start all the repairs we wanted to do. It was a tight spot so he pulled close to a fence and then went to back up to get straightened out. Of course when he pulled up against the fence is when the reverse wouldn't work. So he kept putting it in drive and inched forward then reverse but reverse wouldn't engage. So he tried putting it in 4wd to see if it would get reverse to engage. As soon as he switched from reverse to drive with 4wd on the engine revved wide open. He never even took his foot off the brake. It lunged over the chain link fence. Amazingly it didn't really damage the fence or the vehicle and there was a field on the other side. It moved a good 30 feet before he could get it to stop. He had to turn the key off to get it to quit. Afterward he drove it around the field for a good 20 minutes trying to see if it would happen again and it never did.
Does anyone have any idea what would cause it to rev wide open? I'll explain it one more time. It was in 4wd and he tried reverse and it wouldn't move because of the transfer case. So he went from reverse to drive. The engine was at normal idel and the second it went into drive it was like you put the pedal to the floor. It launched and wouldn't quit until he turned it off. Thanks in advance for your help.
