what did i miss, no reverse after rebuild | Ford Explorer Forums
raymechanic
Douglasville,Ga
1998 Ford Explorer XLT 4w
OK so the quick story is I replaced the timing chains and notice the torque converter bushing stuck on the torque converter. Rebuilt the tranny (new disk/steels plus orings, gaskets and seals, torque converter) got an updated valve body with the superior mods. The bands all checked good and the reverse servo too. Installed trans, filled with merc v (yes I flooded the trans as I reassembled and filled the torque converter before installing). Fired it up got it half way up to temp (about 15 min) put in reverse and nothing. Pushed the truck back and put it into low one and it takes off, same with low 2 and drive. Hooked the computer up and everything is correct on that side. So what did I miss, please help. Thank you in advance
