Aussie Explorer
- June 3, 2005
- Western Australia
- 98 XLT
Rebuilt the LSD but had a problem.
Once all the new Steels and Culches were installed and the spider and side gears back in the axles wouldn’t sit back enough to allow the Cross shaft to clear the ends of the Axle. :thumbdwn:
I changed the position of one of the 0 Rings so it sat behind the C-Clip allowing the axle to sit back a little more but the arrangement was still about ½ a millimetre to tight (More than what the shims were adding)
I ended up having to take .3 of a millimetre off one side and .2 off the other side of the Cross shaft using a grinding wheel and wet and dry sand paper to smooth it out agene.
This then allowed the Cross shaft to slide in with a bit of help with the hammer, but it’s still tight.
Do you think anything bad will occur from shaving ½ a mill of the Cross shaft diameter?
:thumbdwn:
Second question> why the hell was it so tight, when I pulled it out it just fell out soon as the retaining bolt was removed then with the new culches and steels installed the axles ends sitting around a Millimetre further in. The only thing I could think of was the Steels were thinker than the ones I removed, There was only one shim each side and they were real thin so taking them out totally wouldn’t of fixed the problem
Oh and that Pre Load spring is a B**h to get back in, I tried vice grips, pliers, hammering well compressing it with vice grips, I ended up having to put it in a vice and compress the F**k out of it to take some of the “Spring” out of it, than giving it a Good solid belt with a hammer to get it home.
Still got to put the Diff backing plate back on and fill it with oil, bit all indications are it is going to be one Very Tight LSD.
Cheers.
Cheers.
