What is the best Air Cold Intake 1993 XL 4x4 | Ford Explorer Forums
Status
Not open for further replies.
MadExplorer93
Sault Ste Marie, Ontario Canada
1993 XL 4x4 4.0L OHV V6
Thks no longer needed
The only intakes are the KKM, or the Ifab ones. Both use oil filters. Both are not true cold air kits.
You can also make your own.
I would not worry about the oil. It's only a problem if you OVER oil it.
There are no hood scopes made for a 93. You have to custom them. That means cutting your hood. Are the ones you talking about the fake stick on ones?
Yes a cold air setup draws cool air from outside the engine bay. The cone filter setups do not do that. However they still will do something, & are better then the stock intake box.
O-rings in the Intake? Not sure what you mean on that.
Status
