dale88
- January 25, 2009
- 04 XLT
I just pulled the harmonic balancer off to replace it and there is a rubber seal stuck in the camshaft "tube" about a half inch in. Is this seal supposed to be at the back end of the camshft "tube" before you install the new pulley? It appears to be preventing the new pulley from seating. Is a special tool required to remove/install the seal or is there a homemade alternative? Also, are there any special tricks to get the new pulley back on? The installer I rented is not long enough to reach the crank threads through the pulley bolt hole.
2004 Ford Explorer XLT
