What size socket actuates the tire winch | Ford Explorer Forums
alchemist
Baldwin, WI
97 XLT 5.0 AWD and 95 XL
Well I managed to loose my wrench for the winch on the spare tire. What size wrench (socket) do I need in order to lower it? Does anyone know the PN if I have to go and pay the stealer for one if I can't find some other way of making it work.
Umm, it's the jack handle. Parts are under the carpet against the back seat.
-Joe
Nope...they are good and gone.
Figured a socket might actuate it. Guess not. Time to find me a salvage yard.
Have you tried a long 3/8 drive extention?
It's a 9/16" shaft. The end is a flat blade about 1/8" thick x 1" long, centered on the shaft. The last 1/8" is bent over like a little hook.
If you cant find one, I can probably get one from a local salvage yard. Or you can send a PM to kbabiak he may be able to get you one.
If you look at your jack, you will see the same type of slot that is hidden behind the bumper to lower the spare. Find a long, flat bladed screwdriver that has a square shaft. Insert the screwdriver into the acces hole and make sure it fits into the slot, then turn the screwdriver using an open-end wrench on the screwdriver shaft for leverage where needed.
It's going to take a LOOOONG screwdriver to get all the way down there, and, if he ever has a flat, he'll still need the jack handle to use the factory jack to lift the axle off the ground.
However, yes, a screwdriver often works well. If you wanted to kill a screwdriver, I've even seen guys at the local tire shop chuck them up in cordless drills to make the job go a lot faster.
-Joe
